2024-12-26 07:17:02
18.4k
2.4k
Christmas Bells | Christmas Ornaments
@ERAVIA_3338673
BELL ORNAMENT
Available in Five Unique Styles
Includes Tea Light Compatible Versions
Print Instructions & Recommendations
  • No support or any other post processing is needed.
  • Although the published print profile includes 2 Walls, the models are also printable with only 1 Wall as well. However, for stability and quality aspects, it is recommended to 2 Walls.
  • Unless you are printing with a 0.10mm layer height, it is recommended to use variable layer height for optimal quality on top of the bells.
  • The models are designed as solids, meaning the inside is filled by default. To save material and printing time, it is recommended to use above settings. Alternatively, you can choose an infill percentage of your liking to adjust weight and stability based on your display preferences.
  • About tea light compatible versions:
  • Tea light bases are inside the bell models. Please do not worry if it is not visible in the preview.
  • Base comes in two versions where the extended one was designed only to show the lampshade.
  • Both .stl files for the bases can be found inside the folders.
Assembly Instructions
  • Insert a battery-powered LED tea light only (≤39 mm diameter) into the base, align the base with the bottom of the bell, and turn it to secure it in place. Do not use real flame candles, as 3D printed plastics are not heat-resistant.
Model Information
  • Dimensions (X-Y-Z) | Bell: 83~87 x 83~87 x 88.8 mm
  • Dimensions (X-Y-Z) | Tea Light Base Diameter: 39 mm
  • Commercial Use: Terms and conditions are available on Patreon.
Have you checked out Christmas Trees?
christmas
ornament
bell
decoration
christmas ornaments
christmas decoration
